UPB Switch Problems
N49atv
Well today 3 switches decided to stop responding. My furnace room, and both my boys rooms.
They won't go into setup mode, they won't go into reset mode (5 quick then 10 quick)
If I pull the air gap switch they power down. When I plug it back in I get;
1 blue flash
2 red flash
1 blue flash
Solid purple (1-2 sec)
Then blue solid
Any ideas?
What brand?  Not that I'm sure it matters but it could help.
Have you tried moving your PIM to a different outlet on the other phase and maybe closer?
All are HAI. It's not PIM related. I can't turn the switch on locally. It doesn't respond. All of which shouldn't matter with programming. Nothing has changed in 6 months
2 days, and they started working on their own again. I don't see anything in the instructions, they are stock programmed, because I was having blink issues with all of them
Intermittent problems are often attributable to noise.
(although the no manual control is a stumper)
Can you see them in UPStart and talk to them over the powerline now?
I left my laptop in the field office trailer, so I couldn't check.
Previously I could after they smartened up. I'll check tomorrow when I get it back
