Just installed a new Simply Automated switch (the 30th I have installed) controlling a 120 watt lamp load. After just 10 minutes the switch shorted out. Upon removing it it looks like there was a short between the brown load wire and the case (ground) which burned through the wire itself (see picture). Although it no longer controls the load it still seemed to be working (indicator light changing from on to off and slight normal buzzing noise).
My thinking is there was a small defect in the brown wire insulation which led to the short. Would you recommmend (1) try to get replacement from Simply Automated, (2) try to reconnect the switch from the remaining brown wire and see if it really does still work, (3) or something else?
