PaulD
Built my new house to use Cat5e wire in many cases where 22/4 would normally be used. Intent is to use one pair of the Cat5e in lieu of a single wire from the 22/4. I have searched and have not found any standard cross over for Cat5E colored pairs to match up with a common 4 color 22/4. I can create my own standard for my installation but if an standard exist somewhere, I would prefer to use it. Anyone know if such a standard exists?
Also, looking for the best way to physically use the Cat5E wire. Have not been happy so far with the options I have been experimenting with. At 24ga, a Cat5e wire is very difficult to strip and join with other wire or tie to a circuit board connector. My efforts so far to strip the insulation tend to nick the 24gs wire which makes it break easy. Crimps (with tiny internal spikes) seem to work OK for 2 wires but when I crimp 2 ea of the 24ga with a single 22ga or larger, I have not had consistent results. Also trying to keep it neat and the crimps don't help. I am now thinking about new approaches...would like comments if you have tried any of these.
1) Use 110 blocks. I have never used 110 blocks and am not sure how to best use them to tie a Cat5e pair together to a single 22 ga wire.
2) Terminate my Cat5e wire in a standard RJ45 connector and then make my final run via Cat6 (with 22ga) wire to my component. The hope here is that the Cat6 with 22 ga wire will be easier to strip and connect to my devices.
