HI,
I use a mb7052 distance sensor. http://maxbotix.com/documents/XL-MaxSonar-WR_Datasheet.pdf
I know i need to use 3v to 5.5v to operate the sensor. I use the analog pin then plug it to my wc32, but i don't have an acurate reading. I think I may use different voltage to make it accurate.
Is there an other way to do this or i need to adjust each sensor voltage?
thank you again all for your help.
