Hey Martin, I just have a quick question about your set up....
You ran your space heater thru a CR9380-NPN. How many times did you have to wrap the wire thru your CR9380-NPN ?
Also, are you using any other stuff in your setup? ie...burden resistors? Did you just run the wires from your CR9380-NPN directly to your DS10a?
Where did you guys get your short extension cables from? Just a local supply store or something?
B
I'm using CR9321-NPN's, more by trial and error than anything else. I didn't find
the need to wrap the wire, I just put it straight through. I use one of these extensions,
then add another 3 prong plug.
http://www.idealtruevalue.com/servlet/the-64108/Detail
I hook it straight to the ds10 leads, no resistors or other parts. I'm using it with success on stuff
that pulls everything from 350 mA to 11 A.
Thanks again to BSR for pioneering this. It's incredibly useful.
