Before I do the final installation for my 4-wire smokes, I want to make sure I don't cause problems for adding heat detectors next.
Using ELK M1G and System Sensor I3 sensors (everything hard wired)...
Is the best practice to have the heat detectors on their own zone(s), and define the zone(s) as Fire Alarm? Then if a heat detector triggers, since it is defined as a fire alarm, it will trigger the same M1G output used by the smokes/RRS-MOD (i.e., whenever any fire alarm turns on, turn on output 3), which will cause the smokes' integral sounder to sound. Is this the best way to do it?
