completelyhis
I have an inwall cable that is is dvi where my tv is, and dvi where the a/v closet is. As best as I can figure, it is a DVI-D cable, so it should be backwards compatible with DVI-A also, right?
anyway, I want to connect my automation computer (which is in the a/v closet) to the tv. My computer currently only has vga. So, I need to get a vga to hdmi cable, which I can't seem to find. so, here's what I have come up with:
I found a vga to dvi-a cable, which I could connect to a dvi to hdmi adapter, which would connect to the hdmi end of my in wall cable. here are some links to what I am proposing to use:
vga - hdmi
http://www.cablewholesale.com/specs/10v4-05302.htm
hdmi - dvi adapter
http://www.cablewholesale.com/specs/30hd-00300.htm
then i would need an hdmi coupler, because i can't find an hdmi female/dvi female adapter:
http://www.cablewholesale.com/specs/30hh-00400.htm
the cable that most closely resembles the one in my wall:
http://www.cablewholesale.com/specs/hdmi-21550.htm
Is this going to work? It feels a bit frankensteinish at best. I suppose I could get a DVI video card, but it's hard to find an affordable one that's not pci express.
I'm also concerned about the whole dvi-a/dvi-d thing. any thoughts?
vga - hdmi
hdmi - dvi adapter
