Ok, here is what I got. A handful of Vizia RF switches/dimmers all on the 1st floor of my house. In the basement, I have one switch controlling an outdoor outlet that has low voltage transformer plugged in. The switch works for this outlet manually but not in the Zwave network. For some reason I am unable to pair this switch in with the rest of the network. Unfortunatley, this is the only one I didn't install and actually I am not even sure what he did (I was not home). There is a 3 conductor cable coming into the outlet from the panel and no other cable in or out. The black is wired to hot, white to neutral, red to load and copper to ground. I am not sure how the electric is even getting to the outlet outside from here, perhaps there is a wire running from the panel to here also. Sorry for the confusion but does anyone have any guidance. It could be the switch is bad, too far from the rest (probably @ 20-30 ft away) or is there a wiring problem.
Mike
Mike
