Hello all,
I purchased a keypad that I want to add outside the door. I want to be able to enter a pin code on the keypad and the signal from the keypad goes to IP2 on the board to give a signal to OP1 to trigger a relay (that I have in place and working via other cai programing)
Here is the code logic.
START
TSTGT IP2 0
CALLSUB KEYPAD
END
KEYPAD:
SET OP1[1000] 1
SET OP1 0
RET
The problem is that I can see some signal being transmitted to the relay (it has a green light) but it just flickers on and off for the duration and the door does not open.
Any idea why it does not work properly?
It does work properly with the direct code as listed below is I press the TTL1 ON button in the output control. page.
START
TSTEQ OP1[1000] 1
SET OP1 0
RET
END
START
TSTGT IP2 0
CALLSUB KEYPAD
END
KEYPAD:
SET OP1[1000] 1
SET OP1 0
RET
START
TSTEQ OP1[1000] 1
SET OP1 0
RET
END
