webcontroller8 used to drive a pet feeder
bbsux
I have a pet feeder
http://www.amazon.com/Automatic-Feeder-Electronic-Programmable-display/dp/B002X73CBC
that needs new electronics -original was hard to program didn't work correctly half the time.
It uses a motor with a gear system to turn the bowls.  on bowl #1 the is a contact switch that is unhooked, but not in the others.
It used an photo interupter (the main gear has small holes that line up with the sensor when it's lined up with a bowl).
Of course I want it to feed on a schedule.
and maybe add a anti-tamper feature - so it'll reverse to the bowl line up spot if my cat tries to push it to the next one.
and i'd like the ability to use a input with a button to make it rotate to the next bowl so i can refill it
I would this this would all be possible.  Maybe even put a 1wire temp sensor on the motor so if it jams it'll shut down.
Would I use a modified version of example 8 in the manual?  I've never done anything with time based plc coding.
basically have it check for midnight or noon, if it is then power up a output with a relay to power motor, then while motor is on have it be checking for the photo interupter to indicate the bowl is in the right place when it is have motor shut off.
have a button that can activate the motor subroutine for refilling.
legend
motor = op1
button = ip1
photo interupter = aip1
START
CALLSUB TIME
CALLSUB MOTOR
CALLSUB BUTTON
END
SET:
SET RAM1 12:00:00
SET RAM2 00:00:00
RET
TIME:
TESTEQ RAM1 CT
GOTO MOTOR
TESTEQ RAM2 CT
GOTO MOTOR
RET
MOTOR:
SET OP1 1
TESTGE AIP1 ?????
SET OP1 0
RET
BUTTON:
TSTEQ IP1[1000] 1
GOTO MOTOR
RET
here's what I have so far. let me know if you see any glowing errors.  thanks
Glowing, not sure.  Glaring, maybe. :)
START
    CALLSUB TIME
    CALLSUB MOTOR
    CALLSUB BUTTON
END
TIME:
    TESTEQ CT 12:00:00
    CALLSUB FEED
    TESTEQ CT 00:00:00
    CALLSUB FEED
    RET
FEED:
    SET OP1 1
    DELAY 1000
    RET
MOTOR:
    TESTGE AIP1 ?????
    SET OP1 0
    RET
BUTTON:
    TSTEQ IP1[1000]    1
    CALLSUB FEED
    RET
The delay after starting the motor is probably necessary to wait until the sensor goes out of alignment so that the bowl doesn't stop immediately.
