killervette
I have an Elk m1 gold with the ethernet module. is there anything else i need to use the nextalarm service? i see the ABN talked about, but i am not sure if i need it. Also, where in ElkRP do you setup NextAlarm?
NextAlarm cannot communicate with the M1 via the ethernet module. NextAlarm requires either POTS telephone or the ABN module.I have an Elk m1 gold with the ethernet module. is there anything else i need to use the nextalarm service? i see the ABN talked about, but i am not sure if i need it. Also, where in ElkRP do you setup NextAlarm?
The marketing folks would like you to believe that you are REQUIRED to have the ABN module for VOIP use, but there are many of us here that use VOIP without the ABN module and no apparent problems. YMMV and murphy's law says your VOIP issues will be worst when you really needed that alarm notification, rather than a routine arm/disarm notification.NextAlarm cannot communicate with the M1 via the ethernet module. NextAlarm requires either POTS telephone or the ABN module.I have an Elk m1 gold with the ethernet module. is there anything else i need to use the nextalarm service? i see the ABN talked about, but i am not sure if i need it. Also, where in ElkRP do you setup NextAlarm?
look at the new HAI cellular communicator that is now shipping. It runs around $200 (probably a little less), but looks like a regular land line to nextalarm, so you don't have to pay for the extra "cellular" service charge. Of course you have to pay for the cellular service itself, so it might be a wash if you didn't already have service you could piggy back on.
Can you not just use a Uplink Anynet as the primary communications device? why would you buy an ABN and then another item on top of that? Is there a downside of just using the cellular device?
• ABN – Proprietary technology. I couldn’t find a UL listing for the device. The ABN is probably very reliable signaling alarm notification device. There are some unsubstantiated reports on Internet about delayed alarm signals.
