Processor Intel Core 2 Duo Mobile (Merom), Core Duo, Core Solo, Celeron M (4xx series) (Yonah)
Socket M (479 pin) 667 MHz FSB
Chipset Intel 945GM north bridge
ICH7M south bridge
System Memory 2 DDR2 533/667 SDRAM sockets
Up to 4GB memory size (~3.25GB recognizable)
VGA Built-in Intel Graphics with GMA 950 Technology
Expansion Slots 1 PCI
Onboard IDE 1 ATA 133 (40-pin)
Onboard Serial ATA 2 SATA connectors
Onboard USB 8 USB 2.0
Onboard LAN 2 Intel 82541PI 10/100/1000
Onboard Audio Realtek ALC658 5.1 channel AC'97 codec
Back Panel I/O 1 PS2 mouse port
1 PS2 keyboard port
1 VGA port
1 DVI port
2 RS-232 COM ports
2 LAN ports
4 USB 2.0
3 Audio jacks: line-out, line-in, mic-in
Onboard I/O Connectors 2 SATA connectors
2 USB 2.0 connectors for 4 USB ports
1 CD-in connector
1 Front audio connector
2 Fan connectors
ATX power connector
P4 power connector*
BIOS Award BIOS 4Mb flash memory
System Monitoring & Management Watchdog timer, CPU voltage monitoring, Keyboard power on, Timer power on, System power management, AC power failure recovery
Operating Temperature 0 ~ 60°C
Operating Humidity 10% ~ 80% (relative humidity; non-condensing)
Form Factor Mini-ITX (17 cm x 17 cm)
Includes ATA 100 flat cable (40- to 44-pin, 40 conductor,
3 connectors )
2 SATA power cables
2 SATA cables
Back plate
CPU cooler
Utility CD
Drivers CD for 64-bit Windows XP
Operating manual
*This mainboard requires a 12V P4 (molex) power connector from the power supply in order to function properly.
What about the WYSE terminals connected to a central computer (eg: HS)
Lance, a thin client is simply a lean client that is basically a screen whereby the computing is done from a central location. ie, a server with high computing power does all the processing for, lets say, five attached thin clients, thus it appears there are five PC's on a network but in reality its really on ONE processor (or one "pc" with mulitple processors should you chose).
Did I sum that up correctly yall? Been a some years from my tech days.
ps. if you go the thin client route, which can be less expensive, you need to have a pretty heavy duty processing pc/server IF the thin clients will be used alot at once, otherwise its not as important if, say, one thin client is used occassionally, one at time. I will be corrected if i am off base.
keepersq,
What monitor are you using with the Wyse and PH? ELo or another touchscreen?
I wouldn't discount the vga extenders....If you already have cat5 near the location (phone or data) it makes for a very clean install as you have a small cigar sized box, with no power wart (gets power from the transmitter). I use several ELOs with the Cybex Longview extenders (about $75 on ebay) and they carry both the VGA and serial for the touchscreen control. I just use an old PIII remotely located to drive all my screens. The ELO driver supports upto four concurrent serial ports so you can have four screens directly connected serially, and use a reverse KVM or VGA splitter to attach all four monitors to the PC. Granted, all four monitors will show the same thing, but for a family of four, it has NEVER been an issue.
Interesting solution... I didn't know you could run 4 concurrent serial connections for the ELO driver. A lot cheaper than UTMA! I would lose sound but can deal with that. In fact having having 4 screens all show the same thing might be an advantage. And all the benefits of only running 1 PC just like UTMA. I need to look at this some more....
The Cybex longviews also transmit sound both ways (speaker and mic), along with the serial and KVM, depending on the model. So, you can use the speakers on the ELO if you want.
