I don't know what the voice description does in the task screen but it doesn't speak when the task is activated. Add a voice message to the rule to prove that the rule is executing.RogueOne said:Forgot to say that the voice in task 1 was set to say thank you
RogueOne said:When I push button 3 on the elk keypads the green light comes on to show the system is disarmed
RogueOne said:but does not turn on the light or make the panel speak
RogueOne said:The GE keyfob button 3 does make the system speak but does not turn on the lights
That sounds like you have an Insteon problem.RogueOne said:test button does make the voice heard but does not turn on the light. All the keyfobs work. I am using insteon lights through the isy. Elk sees my list of lights
The number 3 button is to check status of the alarm. If alarm is set I push button 3 and it lights up red. If the alarm is disarmed then button 3 lights green. Also explained that way on a couple elk videos I've seen.mikefamig said:
The green light does not mean that the system is disarmed. It is confirmation that the elk has received the keypress
Does the rule for the elk keyfob have a voice command in addition to the lighting command?
I recommend that you get the elk keyfob working before adding a second or third.
Yes that is correctmikefamig said:Didn't you say that you assigned keyfob button 3 to the lighting task?
