johnnynine
I apparently wasn't thinking or just didn't know any better when I had my home wired for whole home audio...
The good:
I have all must in-ceiling speaker wire running to my home theater, which is good for me since that's where the source material currently is.
Currently this is just a single home theater receiver w/radio tuner connected to a squeezebox, radio, dvd, tv, etc.
The goof:
I ran cat-5 from all my in-room volume controls to my structured wiring cans. That has my elk-m1, cable modem, router, etc. I should have ran them to my home theater instead. I currently have mechanical volume controls in each room inline with the speaker wire,but I ran cat5 to them thinking I would upgrade to something more complicated with source buttons, etc.
I do have 3 unused coax cables between the structured wiring can and the home theater that I could use to transfer audio between the two if necessary.
The intent:
Ideally I would want all my sources and a new whole home audio distribution system in the home theater. But since the wiring is goofed I'm not sure that's doable.
Unfortunately I don't have anywhere to place an amplifier and source hardware near the structured wiring cans... WAF would be low if I rigged something up as well.
Does anyone know of a system that uses in wall controllers that I could hub together somehow in the structured wiring can and then pass to the home theater over a single cat5 or coax cable?
Johnny
The good:
The goof:
The intent:
Johnny
