I am in need of a Wi-Fi light sensor. Our facility is quite large and we have an existing Wi-Fi network in place, so Wi-Fi sensors make the most sense. There are not many such sensors commercially available and those that I have been able to find simply sense any presence of light... I need to detect excess levels of light, not just regular light.
First, any suggestions for a commercially available battery operated Wi-Fi light sensor that meets these specs?
Assuming one is not available, I'd appreciate any suggestions as to how I might be able to cobble one together. We have had great luck using the Monnitt brand Wi-Fi sensors for other applications and thought it might be possible to retrofit one of them to function as a light sensor. In particular, They have a
Dry Contact Sensor
-Open/Close Sensor
Analog Voltage Sensor
Unfortunately I cannot yet pits any links to these devices.
Might any of these be able to be retrofit with a photo resistor? If so, what sort of photo cell/photo resistor would I need to use?
Any thoughts, suggestions, or recommendations you can make would be tremendously helpful.
Dry Contact Sensor
-Open/Close Sensor
