I am working on hooking up an Elk M1 Gold and got a Optex AX-70TN to place across my driveway. The location this will be located is approximately 250ft from the main panel. I ordered some direct burial 18 gauge wire to run for the contact portion of the sensor and I think that should be adequate? Is there a maximum distance to run zones on the M1?
The Optex AX-70TN takes 10.5 - 28V DC @ 38mA max. My next question is how should I power this? I have 120V AC available close by and could use a 24v or similar wall wart in an electrical box outside, but I was concerned about the longevity of a cheap wall wart. Should I invest in a better DC power supply and then run wire 250ft to the sensor? If so, any recommendations on power supply or wire size for this?
Thanks for the help.
