jeffmowens
Hi all... hopefully one of you will be able to help me diagnose this problem.
We have an Omni IIe v3.2 firmware successfully installed and operational. Attached is a X10 PRO PSC05 2-way powerline interface that also successfully sends X10 commands to a small handful of property lighting (floods, etc.).
Recently, we were adding an extra X10 flood w/ motion (the kind that has the +1 options to send X10 to turn on other devices when it triggers). The flood operates as expected and tests show its +1 sending is working fine as well as we've witnessed the other devices turning on.
So, if the Omni can send commands to all these X10 devices, including the new motion/flood, with the PSC05 we should also be able to "see" X10 as well and react, correct?
The PSC05' LED blinks when it detects X10 on the line (eg. the new motion's trigger) but the Omni doesn't register any of the X10 on the line....??
We check the unit status via PCAccess -- no updates.
We set a very simple automation trigger (eg. WHEN X-10 B 6, THEN X-10 Unit 13 ON) -- nothing either.
Any thoughts, suggestions?
Thanks for the help! B)
