JustCurious
Bought Honeywell Z Wave thermostat with hopes to switch thermostat in energy saving mode when system is armed. Rule configured in ELK M1 did put thermostat in "Temporary Hold" mode at desired temperature. However, switching it back into Programming mode when system is disarmed was not possible. The only option available in M1 is to set it to another temperature. It seems like I have to use M1 to run the heat/cool schedule, with this I will loose fan auto circulation mode (run ~35% of the time). Did anyone faced the same issue? Are there any ASCII text strings I could send to the controller to remove M1 "hold" on the thermostat?
Current setup
ELK M1 Gold
ELK-M1XSLZW
Leviton VRC0P-1LW
Honeywell TH8320ZW1000
Thank you.
Current setup
ELK M1 Gold
ELK-M1XSLZW
Leviton VRC0P-1LW
Thank you.
