sanders2222
I powered up my M1G today, essentially for a bench test. The keypad was recognized but then I had a number of "Zone violated" messages (11 zones that are not connected to anything) plus "Area 1"/"Output 2 Trouble" messages (see thumbnails).
To address the Zone messages, do I need to short the connections on the panel that are not used?
Output 2 is for a "horn" in my attic (currently not hooked up). So the system either needs a horn connected or some other problem exists. Is there a way to run the system without a horn or is there another potential issue?
I assume "Area 1" refers to defined locations, by default all zones/outputs fall under area 1 until I define others. Is my assumption here correct?
