I have two Yale ZWave deadbolt locks connected to my Elk via a M1XSLZW.
Here is what I have working:
However, if I command the lock to lock via ZWave and there is a jam I do not see the notification anywhere. This is important as I arm the system and walk away from my house. After the 60 second exit delay the lock will lock and if there is a jam, then I want to know.
Any ideas?
I know the suggestion is usually to put a sensor in the deadbolt "chamber" to ensure the lock is fully engaged. I plan on doing that for one lock as it is near a keypad and easy to wire. However, the other lock is part of a french door.
Any suggestions would be greatly appreciated.
- I can lock and unlock each lock
- I can view the lock status (locked vs. unlocked)
- I can check the battery status of each look
- If I press the keypad and a lock is jammed I view a message on the keypad and it will email/txt me
Any ideas?
