Bzncrewjr
Ben lost me here
[*]On SmartThings web site (https://graph.api.smartthings.com)
[*]First you will need to add a new device type called Accessory Switch (see below)
[*]Select My Devices tab
[*]Make note of the Device Network ID of your secondary controller you will need this later
Make a note of WHAT? Smart Things doesn't identify the ID. The app has little to say about the secondary controller. It's named Leviton Remote. So what do I do here? I'm Dead In the Water.
This is why these instructions are of no use to me. Perhaps I'm too newb for this.
Here are his instructions:
Collaborative sourced from jkmonroe, batwater, ivb
v1.0 2/25/2016
Steps to add a device(s) to the SmartThings Hub and a Secondary ZWAVE controller like the VRC0P that CQC can recognize and react to
[*]Select your newly added device by clicking on the hyperlink of the name of your device (the device will have a hyperlink name in the Display Name Column)
[*]Click on Edit at bottom
[*]Make note of the device type *** Important ***
[*]Change device type to Accessory Switch (from step 1)
[*]To associate to VRC0P (or other secondary Controller)
[*]Set the device type back to what was noted in step 4
[*]Repeat steps 4 - 9 for each new device
[*]There is no dedicated replicate button.
[*]If you follow these steps exactly, you will successfully replicate to the VRC0P.
[*]Open your ST app and walk to your VRC0P
[*]Press the button on the VRC0P until it turns amber (not red, amber/orange)
[*]Hit 'Connect New Device' (the top option under Marketplace in the SmartThings app)
[*]Once the VRC0P button turns green back out of the "New Device scan"
[*] In CQC in the ZWave Device Driver config hit the rescan button
[*] Configure your device(s) - Note it is possible to add multiple devices and then update in CQC
[*]Replicate to the VRCOP (from jkmonroe)
[*]CQC
New Device Type (from jkmonroe)
We need to configure the non-beaming devices to associate back to the VRC0P. Since the VRC0P/CQC will never see these devices, this step must be done manually. It is the most complex part of making this all work.
- n SmartThings App
Add new device(s)
v1.0 2/25/2016
- In SmartThings App
Add new device(s)
- Go to Preferences box click edit
- Set to association group 1 and assign the Target switch Device Network ID of the secondary controller (from step 3)
- Wake the device up
- Save and immediately wake the device up again to receive programming
[*]CQC
- Log into the SmartThings API at https://graph.api.smartthings.com/
- Across the top, click ‘My Device Types’
- On the right, click the green box that says + New Device Type
- the top of this form has 3 tabs, click ‘From Code’
- VERY IMPORTANT TO ONLY DO THE ABOVE
- PLEASE DON'T FILL OUT ANY RANDOM INFORMATION
- JUST CLICK FROM CODE
- Copy the code found at this url https://gist.github.com/mckeed/182cc9689299e20af17b from the word metadata to the closing } at the end
- Paste in the code
- again, don’t make any changes
- With the code pasted into the window, hit Publish and then "For Me"
- Now hit Save
- At the very top of the screen, click ‘My Device Types’ again
- you should see a namespace called ‘mckeed : Accessory Switch’
jkmonroe said:Yes.
With SmartThings as the primary controller, you need to include the VRC0P, and then need to follow the directions Ben typed up.
