Use a non-dimming switch - One with a relay might work. Chances are the 2 wires you are referring to are not line voltage.I have a two wire cable that is connected to my fireplace and tryed connecting a 15amp Zwave Leviton switch, but it did not work. anybody know what i would need to make this work?
See this old thread for some insight. http://cocoontech.com/forums/topic/14921-gas-fireplace/I think its low volt. i tryed both switches, dimer and 15 amp line load. If it is low volt, what shoul i use? they make a 1.5amp for fans but i am not sure if that will work. at 80 bucks a pop, its kind of hard to "try and see"
In my case, because desire to have a fire on had nothing to do with the temperature; but the ambiance. That, and I already had power nearby, but not the necessary control wires to interface a thermostat. The UPB solution in my signature worked beautifully.
Sure - but it would add the cost of a thermostat (including the eyesore of an additional thermostat for no reason); and then I'd need a way to wire it. If you look at the post in my signature, you'll see that what I did was well thought out and perfect for my situation without adding clutter or expense.But you can still do that with just the Tstat. One of the Omni's will do it. I had that set up when I had a gas fireplace and it works perfectly.
I hate to be that guy, but the reality is, 99% of the people you get on the phone quoting specs or capabilities have their heads up their *****. They are placating fears with no actual knowledge to speak of. I wouldn't trust anything I heard over the phone from someone unless they can back it up with real information that makes sense. I know that what I did was borderline against code, but I also know it's 100% safe, and even with a wife and 3 kids, I am completely comfortable with what I did. I challenge anyone with the appropriate credentials to dispute that.I have a similar setup, microvolt attached to a regular switch, the voltage comes from the gas line. I called the manufacturer and they stated that it is absolutely forbidden to run high voltage in the same box as the microvoltage wires due to the risk of causing an explosion. So that rules out any HA switch. Unfortunately the switch is currently mounted in a dual gang box with a regular light switch which was not caught by the inspector. As a safety I wrapped both switches with electrical tape for the time being until I can think of a safer solution.
So before you do anything, I recommend you call the fireplace manufacturer and see what they recommend...
