This morning the GXV3672HD was off line.
The network cable connection was not wet.
I did an end to end check of the cable in question and it is fine. Indicator leds on the POE switch that it was connected to (not the Tycon mid stream switch) were not on. I moved another POE device to same said port and POE lamp LED went on. (so the POE switch is working).
I took the test cat5e cable over to a separate 48VAC injector and it powered up the GXV3672HD.
I went to the IP of the camera and all appears to be running just fine.
I am not sure what to make of this yet. I am though taking the camera inside to change the lens.
That said I will leave it running inside for a bit (a week or two maybe?).
Interesting is that I had thought also something was wrong with the camera cuz the HD picture was a bit fuzzy. That said I forgot I had let the primary stream settings at MJPEG. World of difference when switching it back to the H264 stream.
