Is the 173.194.68.26 address belonging to GMX or a different provider ? I'd do a telnet -a to the provider and confirm the ip address . I think the elk m1 is very sensitive to hostnames/ip addresses that are not resolvingBig517 said:Hmmm.. maybe the m1xep does not convert URL to IP which is causing the crash... I'll try 173.194.68.26
Edit: NOPE. Crashed again...
vbdino said:My DVR was also failing to send e-mail on port 25. The port can't be change and ssl is not supported. SMTP2GO was not working for port 25.
So I finally got something working by using MailEnable Standard which is free. It is a complete mail server running on top of Windows IIS. I installed it on my laptop which is allways running with Windows 7. I configured it to relay e-mails to smtp2go using the option SMTP Smart Host. Without this option, e-mails are relayed successfully to Bell Canada but not to Blackberry.
There is probably easiers ways.
Searching through internet, it could be that my ISP is blocking outgoing SMTP protocol for port 25.
MGotcha said:I am Back to attempting to get my M1 Email functioning (to send SMS notifications) after attempting to use cox, gmail, yahoo and AOL mail accounts in the past with no success (I use COX for internet). I setup a SMTP2GO account today and tested it by setting up an account in Mozilla Thunderbird (no security/SLL) and was able to send a message via SMTP2GO (it showed up in their report list screen, and I received the SMS). I then connected to the M1 with RP2 and setup the M1XEP Email with the appropriate SMTP2GO credentials, using port 2525 as I did in Thunderbird, Clicked Send and then reboot and then re-connected and tried the "Test" button and RP2 indicated it was sending the eMail. No SMS was received and the SMTP2GO report screen indicated no message was sent. I also tried the other ports recommended by SMTP2GO , and a test rule I have setup (while RP2 was NOT connected) with no success. SMTP2GO seemed to be a perfect solution for the M1XEP but it is not working out for me. An suggestions?
