I am trying to control my air exchange unit and dehumidifier using the HAI RC2000 thermostat. I have my dehumidifier and air exchange units set up using relays in the HAI OmniPro 11 panel. I can manually turn the units in in PC Access by turning the relays on, so that part works.
The problem I have is trying to take the outputs for heating system On and humidity on the thermostat and getting the OmniPro system to do something with it.
I have tried to have a flag set when the thermostat turns on the heating system and another flag when the humidity goes above the set limit on the thermostat. The system sees the change but what ever I set up in programming using PCAccess will not set a flag.
I have HaikuHelper but I am not able to write software using it. I am only able to use the basic interphase that it has.
Any ideas?
Any ideas?
