So I got these things on wednesday and I promptly hooked one of them up. I've got two zones on it now, with keypads. I had to wire one of the zones, but the other was already wired because it had some kind of IR/keypad thing from the mid 90's (which was good, because that zone was 2 floors up and on the other side of the house).
I gotta say, it works really nice, and sounds great. I have a bunch of 20 year old Infinity wall speakers and the surrounds are starting to fall apart. Since I bought some Monoprice 4101's, I cranked the volume to max with some metal on pause, unpaused it, and the surrounds blew out a couple of feet and floated to the ground.
I then put the 4101's in. They sound GREAT. Not a ton of bass for a 8", but no wall speakers I've heard has a lot of bass since they are designed for an infinite enclosure. But, it's still enough for casual listening.
This thing sounds WAY better than my 200W Sony receiver running through the old Niles gear with impedance matching volume controls. I'm impressed.
I haven't gotten around to playing with the serial protocol yet, I'm waiting for my 4-port Wiznet IP->serial converter to arrive and then I'll write a plugin for the Vera. Thinking about writing a mobile app also. Anyone have suggestions for a good mobile framework that's free and will let me cross compile to multiple platforms?
I also haven't gotten around to hooking up the paging thing yet. I just switch my zones back to zone 1 when I'm done listening to music.
One of the things I did was to buy a Homespot bluetooth audio receiver from Amazon. They are like $28, and the range is awesome. I can stream to it from 90% of my house, and it's down in the basement in a utility room sitting on a shelf on a telco rack. It's got an NFC thing on it for pairing, and for switching your phone to it after it's already paired. I cloned the NFC tag in the unit and made copies of it. I stuck them on the Decora plates around the volume controls. So now, if I'm in a room, I can tap my phone on the plate, and play music to that room.
I haven't taken them apart yet to see if there are any identifying marks inside on who the manufacturer is. Just glancing at it, it doesn't appear there is a warranty void sticker on it. Maybe I'll get around to it this weekend.
Another thing I noticed is that the "hub" for the keypads is mounted on a decora plate. I wish there was a wiring diagram for it so I could punch down wires on the back of a patch panel to make my own hub. There's no electronics on it that I can see, only traces. And each wire appears to only use 4 conductors. The instructions say you need cat5e or cat6, but my one keypad is on over 100 feet of plain cat5 installed 20 years ago, and it works fine.
About the only thing "cheap" about this thing is the remote that came with it. But, I would assume that most people would just use it to program a nice remote.
