Sure you can. Check out the android app called trigger. In trigger you can set the nfc tag as event and set a tasker task as the event. I assume you have the m1xep. It's then a matter of setting the tasker task to issue the disarm command via http. Check out the m1 control protocol. It's hosted here somewhere.
