I have not tried this yet, but I know the GC keypads have IR "eyes" and that the GC comes with IR blasters that can be plugged in to the back of the main GC box. I would assume that you can take your CD players stock remote and have the GC keypad send the IR signal to the GC which would then echo/blast the IR to the CD player.
Let us know if it works.
Well, you guys were right. It was easy to get the software from NuVo. Picked up a USB-Serial Converter from Fry's and I was off to the races. Got my sources renamed, no problem.
Now, as far as controlling my CD Player goes. Ace is pointing out that I can do an IR passthrough from the keypads to the device - which isn't quite what I want to do. I want to have those codes known to the GC, so that when I use the buttons on the keypad (to change track or play/pause), That it tells the CD Player to do that.
Well, there are SOME built in IR libraries, but they are very limited. However, you can easily add a device, and you don't need the learning station to add the codes, you can add Hex Codes directly. Well, Google found me the hex codes (thanks to the guys at remotecentral), and I got them added. I can taste victory.
However, whenever I try to edit a button macro (which is what I need to do to make the 'forward' button execute the 'next track' command, the configurator software hangs up. That's where I am now. Allegedly, some macro editing window is supposed to open which is where I can create/edit these macros, but I get the hourglass and nothing happens.
I'm running this on an Acer Aspire One netbook, and am a longtime Mac guy not a windows guy, so the troubleshooting on this machine is not something I have a lot of experience with. Anyone else have any trouble with the macro editing window?
