Why is the omni so vulnerable to network traffic?
Because of the design of the integration of the NIC chip to fit with a serial bus designed board.
Opened a ticket a few years ago with Leviton. They stated no fix at the time for an overly promiscuous NIC port which took down the serial bus on the panel.
Have a read here ==> it is buried here a few years ago (2013)
Home Automation, Inc (HAI)
I saw this issue crop up when I went over 50 devices on my network a few years back.
Leviton did try to fix it in the firmware and did not succeed.
The fix is to route the traffic from the Ethernet port using a firewall or a L2/L3 managed switch.
I figured this out testing with old hubs and managed L2 switches a few years back (2013)
The fix I used here was a micro travel router with two NICs powered by a bucky transformer (Panel 12VDC ==> 5VDC) and shutting off the Wireless radio.
Specifically I used a XXX with OpenWRT firmware. It fits between the daughter boards on the OP2 and the side wall of the HAI can.
Since implementation I have not had issues with my time sync, serial bus devices (consoles, thermostats, Omnitouch 5.7 screens) and network port.
Made a sticky on the Homeseer forum over here ==>
Microrouter DIY for use with the Omni Pro Panel Ethernet port
Today you can just plug the port in to a managed L2/L3 switch and route the traffic from OmniPro 2 panel.
