@rsw686
Good news! Thank you rsw686!
Got it running now on the Ubuntu 16.04/64 bit server. I see the web page now. Found out too that the event log was going to the root.
I see the booting stuff in the event log and via command line.
IE: mono HAILogger.exe -i and mono-service HAILogger.exe
IE:
HAILogger resides in the root as /HAILogger
The event log is being written to the root as:
HAILogger\EventLog.txt
Tested on RPi Jessie and it works fine there too.
Here switched over to using the RPi's as slaves now for Homeseer and testing the Pine64 2Gb (a little larger than the RPi) running Ubuntu 16.04 / 64 bit server and the mini pc Xi3 / Xi5a also running Ubuntu 16.04 server now.The Xi5a is much larger than an RPi.
The Pine64 / 2Gb and RPi computer has an RTC with battery on it.
Been goofing around with OpenWRT only there is no space for compiling c or using Mono. That said I can maybe build a virtual box with OpenWRT and give it a try? Only have 400Mhz single core computer chip though.
These devices are smaller than an RPi, have built in two NIC ports and wireless and here have added RTC to my test devices (1" X 2") powered now by the OmniPro 2 panel.
