FlyingDiver
Do you see the same port forwarding rule match when you connect via the cellular (phone) network?
rbarnes said:Update. I have just checked my home router to check the forwarding etc and found that my office connection is getting to my router with the following entry
[Elk rule match] from xxx.xxx.xxx.xxx:59824 to xxx.xxx.xxx.xxx:2601 Wednesday, July 16,2014 15:26:38
So to me that appears that i am getting out from my office to my home router.
But what does that mean as far as why i cant connect? Im lost!
wuench said:As I mentioned above, the error seems to indicate you are getting connected and it is failing at the authentication phase which rules out the network connectivity. And it sound like you have pretty much verified that connectivity as well. I would double check all of your auth settings and then if that all looks good, download wireshark and take a trace, it might to narrow down the issue.
I also assume we are talking about ElkRP here and not ElkRM (the web interface).
