Cavi said:I'm going to see if I can get my hands on a multi-meter so I can measure the EoLRs. Will this value dictate which panels I'll be able to buy? I'm still looking at Honeywell/Ademco options, and found this starter kit as a viable option. The ones you guys are suggesting are just really expensive. I've also looked at options from Elk since it seems popular on this board. I've decided I want to go cellular so I don't have to sign up for POTS. I've also found that my basement window is covered in my current system, but that sensor is wireless.
I've also talked to a couple of companies about coming out, and by the time you add cellular and total connect, the monthly fee is over $40! Crazy. If I can manage this for half that, I'll be a happy camper.
Is there any way of finding out from the pic I posted of my panel whether it's DSC or Honeywell manufactured? I've heard those two used commonly, and if it's honeywell, that might indicate the sensors would play nicer with the stuff I'm looking at.
Your panel was manufactured by Scantronic, and it is essentially a customized model that they made for Brinks. It uses different value EOLRs than DSC or Honeywell (4.7K vs 5.6K for DSC and 2K for Honeywell). As ano said, in many cases the EOLRs are not installed, so that would make it very easy to go with pretty much any brand of replacement.
I'm not sure how your wireless sensor on the basement window is interfacing to the alarm panel. Is there a wireless receiver somewhere connected to the panel?
