You appear to have an agenda.
SA street prices are lower than HAI and PCS.
Gen I or II isn't a huge deal.
Most of the firmware improvements of "Gen II" are incorporated in the SA units without the corresponding lower sensitivity.
SA has some products that are simply not available with other vendors.
Im thinking I dont want Alezis to change my mind, lol. Something is up with that.
SA products are just fine and I wont hammer you on choosing SA over HAI. SA is not 3x times the price Alez, will assume you just had a typo there.
I prefer the breadth of product offers in the SA line up. That leaves me with asking myself why wouldnt I use SA? I have a mix of SA (almost 80 loads) and few HAI's sprinkled in. I sure cant tell the difference in performance. Granted, I havent done any Omni programming yet, just Upstart, as we just got the switches put in and havent tackled that project yet. I dont even have a coupler or anything else installed and perfermance is fantastic. Im assuming I will need the coupler at some point, maybe needed once I start getting the lights automated via Ominpro? Not sure. AND I have four panel boxes in my house. I just cant believe it all works so far, lol. My understanding was you MUST have a coupler. I have tried to enroll/find a couple switches via PC Access with not luck so it could be the no coupler or Im just not doing it right.
Alezis - you're pushing the issues "why would one buy SA when they may have compatibility issues"... so try this - how about asking, has there been a single reported issue of compatibility problems with SA and any type of light bulb? Any problems with CFL's, LED's, or any other type? I've been around this board for 6 years and haven't heard of one.
Part of the deal with UPB is licensing the technology; It could be argued that the only point of going to Gen II or Gen III is so that PCS, the inventor of UPB, can get more licensing revenue. From what I understand, most of these improvements were already in SA switches before new generations were introduced.
Simply Automated has some huge advantages; just look at my signature; one can pick from 2 models that will cover 99% of their house. The products work great and require little tuning if any. As above, often it doesn't even require a phase coupler (in those cases, the signal is strong enough to travel back to the transformer and jump phases and return to the house).
It's fine for anyone to ask questions and learn, but you're at a point where it sounds like you're putting the OP down because of some phantom problems that probably don't exist. Your tone is very off-putting. And in your less than 24-hours of membership to this forum, you've blown up this thread and its members over this topic.
Regarding programming from the Omni - yes, it's an option; but if you fully understand how the HLC protocol works, there's also nothing wrong with programming via Upstart as long as you keep the whole Room convention together; if I understand correctly, you get more flexibility in using Upstart.
BTW, if someone really thought they cared about GenII on a SA switch, a company called WebMountain sells SA switches that they have reflashed with GenII firmware (a process that users can't do); but again, 6 years of watching this stuff, and I haven't heard of anyone doing it or needing to.
And lastly - I know retail and wholesale prices for all these switches, and SA tends to be 1/2 to 1/3 the price of the HAI or PCS switches.
And actually, I'll take that back - there's one user of these forums that will go on about only using GenII devices because he doesn't believe in fixing the noise problems but wants something that can push through them. He had a noisy range and pool pump and didn't believe in fixing the noise source.
My last point was that I don't understand why someone with a Omni Pro II would choose to program their UPB devices regardless the brand with upstart since the omni pro II handle all of your network in a neat way. If you are running stand alone, I hear you but when you have a controller that is made to run these UPB device, why not use it ? I never said it was wrong using upstart.
By the way, why did you not use your omni pro II in the begining to program all your UPB devices ? The HAI system coordinate everything so you get a good response with proper feedback. I would understand your procedure withouy a controller but having a fine controller like the omni pro II, I think it is a must to use it to program your UPB devices.
There are several reasons to use UPStart. A simple one is that the HAI model of a room controller and 7 units does not always work - especially for rooms where you want more than 7 loads. Because UPB devices actually have 16 links that they can respond to, it's easy to use UPStart to allow multiple rooms to work together. Programming via the HAI panel can't do this, but via UPStart, you can.
I use UpStart to customize behavior, to modify the default HLC behaviors and to include units in links across HLC rooms.
HLC and custom configs in UpStart work very well in concert with one another.
As for LEDs and SA switches, I have more than 50 Cree CR6 lamps in my home all being controlled with SA switches.
Dimming performance and general response to links is excellent.
