I am curious to know how you are handling your individual smoke detector zones?You can home run each smoke detector, but I don't think it is worth it. If there is a fire, you just want to get out of the house. Who cares which sensor triggered.
If the alarm goes off, I'd rather not have to stop and wonder "Hmmm, i wonder where the fire is. Let me take a random guess, and keep going from room to room, wondering, and hoping I don't encounter a situation where the fire is between me & the kids".
There's places to scrimp & save in Security, but the $11 that the extra wire will cost is certainly not one of them.
Is 22/4 fire rated an ok substitue for 18/4 fire rated for smokes? didnt want to have to buy a huge roll of 18/4 and not really need it.
also, (i live in ankeny, Iowa, if you need to know) does my cat5 and 22/4 need to be terminated for inspection? i will not be buying the elk stuff right away, maybe in a month or so.
I'll be the first to appreciate having every single sensor in a security system on its own zone, but most 4 bedroom houses are going to have 8 to 12 smoke detectors. If you put each detector on its own zone, it seems to me that the cost and complexity goes up astronomically. It is not just the extra cost of wire. Most people will need an additional input expander just to handle the smoke detector zones. Plus, if each device is on its own zone, to do it right, aren't you committed to 4 wire smoke detectors. I believe each chain requires its own EOL advisory relay. Then how do you interconnect the sounders. Are you putting a siren/sounder in each sleeping chamber and in all the common areas? Or if you are using low voltage smoke detectors with integral sounders, are you putting a reversing relay on every single zone so that you can trigger the sounders? The cost and complexity of these extras seem significant. You almost need a separate enclosure just to handle the extra components. This is one of the reasons why I suggested keeping all the smoke detectors in a chain on Elk's 2 wire zone (16).
is 22/4 fire rated an ok substitue for 18/4 fire rated for smokes? didnt want to have to buy a huge roll of 18/4 and not really need it.
I know you said 'security', but we've learned long ago that 'security' term can be stretched pretty far. So if I was building a house and had lots of cheap Cat5 available I'd run a drop to every light switch location (just don't terminate it inside the box..) for future hardwired lighting automation. I'd also run another drop of Cat5 to each switch for audio control and either run speaker wires from there to a couple of locations in each room or homerun speaker wires from each room to a central location.
Just saying, 'cause once you get started...
I kind of wishes i had used 66 blocks to terminate all the alarm wiring. At the moment I have a ton of spare and 'future' wiring that is just hanging loose (coiled) and is a bit in the way. At least with 66 blocks you could terminate everything on there (including spares and future) and things would be neater.
Use 110 blocks. Same idea, but cat5e compliant if you decide to patch a couple of network runs through it. Plus, it's what most people are using now, except for the old guys that have been doing it for a LONG time and don't want to switch.
