Rob,
Sounds like you've got a few nice toys to play with now! For the logs on your property I would strongly suggest taking them to a local lumber mill to have them cut up. There's a real skill to it and experience makes a big difference in the yield you'll get from each log. Even if the logs themselves are small, your 14" bandsaw isn't going to do them any justice at all.
Local mills (expecially the hardwood mills in your area) would be happy to do this for you. Them may even come pick up the logs if you don't have the means to get them moved. You could have them simply cut them into slabs for you and you can take them home and stack them away for a few years to dry (use LOTS and LOTS of stickers between every board no more than 2' apart - and the bigger/heavier the stack the better chance of having good lumber when it dries). If you have more logs than you plan to use, you can probably even trade them some of the leftovers for the cutting. You could have them leave them as slabs or rough cut the lumber into something easier to deal with at home. Also, if they have a kiln, you may be able to get them to dry some or all of the rough cut lumber. Of course trading lumber for labor would be a consideration.
One caution is many are very shy to cut logs which were harvested near the road or fence line. Many times steel from fence staples, nails or whatever get embedded deep into the wood in trees which are more readily accessible. Many mills have metal detectors to search for steel, etc because anything like that which hits a blade in the mill can be disasterous (less so with a band mill). Snow plow like to chuck rocks into the crotches of trees, etc which also cause problems. So the further into the woods the logs come from the more likely you'll find someone to help.
When I lived in MI, I had a 30" rough planer and large joiner and other equipment which handled this type of work pretty well. But the "art" of the process proved to be far more important than I originally though and the deals you can make with these small (usually) family owned mills are too good to mess with it.
Anyhow, sounds like fun! I you really want to have fun find a nice burl (knarly crotch section or root ball) of a black walnut tree and have that cut into slabs. In a few years you'll have some of the most beautiful wood to make smaller items from (gun stocks usually come from these sections). As a previous poster already mentioned, quarter-sawn oak (and other species) makes really pretty surfaces.
If you do any serious wood working at all, I'd recommend buying a moisture meter as one of my first investments.
