I am trying to turn on my F4 key LED light when the lighting status of my garage sensor is open. It looks like it is easy enough to light it up based on the status of an output or about a million different other things but it does not look like I can use a custom variable or a counter or anything else. Is setting an output the only way to get a status change that the Elk keypad can see? Is there another status I can set? I see many status objects in the dropdown in the keypad setup, but I am not sure if I can use those for my own purposes.
If an output is what I need to use then what is an acceptable output to use that is not reserved. I found out the loud way when I tried to use output1
which seems to set off the siren.
