I'm in the wiring stages of a new house and was wondering if anybody had opinions on whether to install two wire or four wire smoke detectors? All the detectors will be homerunned into the equipment room. Also i'll be integrating with the elk m1g and cqc.
I still prefer 2 wire. One zone, one series wire, "clean me" feature.
I'm a little fuzzy on the "Clean Me" feature.....what is it? Also, I will have approximately 14 - 16 Detectors that will be homerunned. On homerunning a zone, do you wire to one smoke, then another, then homerun to the equipment closet? Besides cost of wire, why wouldnt I want to homerun each individual detector the the Elk panel? I would prefer that when the smokes go off and alert the fire dept., for it to also state the room it originated in. This is why I didnt know if it was feasable to homerun all the smokes individually. Also, would each individual smoke require a power supervision relay at the end? This is new construction. Your thoughts are appreciated.
It's really a tradeoff and depends on what you really want. 2 wire is wired daisy chain to each other and requires 1 EOL and hooks to zone 16. You can get the clean me feature, but you lose zoning. 4 wire you need an extra Elk expansion card for that many zones and you need a relay for each one as well. It will cost you more but you can get full zoning. So its really a personal choice - both 2 and 4 wire detectors are essentially the same quality.I'm a little fuzzy on the "Clean Me" feature.....what is it? Also, I will have approximately 14 - 16 Detectors that will be homerunned. On homerunning a zone, do you wire to one smoke, then another, then homerun to the equipment closet? Besides cost of wire, why wouldnt I want to homerun each individual detector the the Elk panel? I would prefer that when the smokes go off and alert the fire dept., for it to also state the room it originated in. This is why I didnt know if it was feasable to homerun all the smokes individually. Also, would each individual smoke require a power supervision relay at the end? This is new construction. Your thoughts are appreciated.
You only need one relay if you daisy-chain the power. (You can get the smoke with a relay built-in also)
Brian
