Hi!
I am trying to power the 4 channel relay locally. But when I connect the power (12v DC) to +12v and GND then I loose the connection to the 1-wire net!?
If I remove the power I get connection again? Any ideas on how to solve the problem (I have removed the jumper JP1)?
Hi!
I'm not sure what might be going on. Are you sure that you are connecting the +12v and GND to the correct connectors?
Eric
I found a 9v adapter and with this one it finally worked!?
