I'm about to click "buy" on an order to add cellular reporting to an M1 system that is already using NextAlarm.
I would appreciate a "sanity check" from those who know these parts.
I have two choices for the communicator:
I'm guessing the first of each set go together as do the second of each set and that either set works. Is this the correct? Or is one pair "better"?
Of course, I need an XSP too, then need to register the Uplink with NextAlarm so they can activate it with the additional $7 /month fee.
With this, I'm presuming that I can switch to cellular as the primary monitoring with both alarms and event notification.
Thanks for the review.
- Uplink 2500SER, listed as "25 pin serial anynet for Elk panel"
- there's also a 2500STD listed, which I'm presuming uses the molex connector? It appears to be more popular. Same price.
- Uplink 1000CAB Cable serial for use with Elk Panel
- Uplink 24450300 9-25-PIN-Female-Serial Plug Cable
