TrojanHorse said:
I have Verizon which I think has longer runway on 3G
Yes and no. Their original plan was by the end of 2019. Then they extended that until the end of 2020. Now they have extended it with no set timetable. So initially theirs was shorter, the revised was still shorter.
That also means that next month they could revise the date further. Chances are, it is one or a few big customers that pushed for this and everyone else, not a concern.
The sad thing is, while 5G is not widely deployed, where are the 5G capable devices for say alarm panels? Currently those are LTE but just wait until 6G comes around and LTE is being looked at being phased out. A 5G modem while it costs more, is still cheap compared to the overall BOM.
5G chipset is $50 to $70 for the budget line and the top of the line in is around $130.
4G chipset is around $40.
So a 5G does cost more but the budget chip could be used as how much data is an alarm panel going to transmit? It is not like it needs high speeds that 5G can offer. It would extend the life of the device though. As it stands right now, a lot of devices are are N-1 in terms of technology and thus has a short life.
1G (AMPS) was shutdown in 2007
2G was 2018 - 2020 (different carriers had different dates)
3G is 2022 -202x
The bigger issue, long before the sunset actually occurs, the network was already in the process of being decommissioned. They remove support from some towers and let other towers cover the area. So the network was not once it was in the past. So chances are, AT&T has already removed towers from supporting 3G and so has Verizon even though Verizon doesn't have a date set for when it will be turned off.
