I am looking to start new into some home automation. I have no home automation today beyond ability to remotely control my security panel (see below for more detail).
Here's an initial list of things I want to do from an automation standpoint:
The entire house is LED lighting and dimming is needed in some areas and an obvious requirement is to have dimmers that don't make audible noises and can dim LED's appropriately. Currently I use all Lutron CL dimmers and they work perfectly.
I have a Vista 21iP system which I DIY installed and have fully monitored with TC2.0. I'm in a situation where I have a 2G communicator and I can't upgrade the add-on communicator due to incompatible panel firmware. I don't want to add an external communicator so it means a bull board swap w/new communicator. Given that cost, I'm open to swapping out to a new panel. Most of the house is wired but I do have some wireless Honeywell zones that would be nice to keep (3 windows, 2 smoke, 1 CO) in order to not have to re-buy that gear.
From a security camera standpoint, this will be new installation and the plan at the moment is to use all Hikvision cameras and NVR, but I'm also considering Dahua. From what I've seen so far, both offer enough in the API to do the things I want to do as described above. Note that I'm not expecting there to be an out-of-the-box point-n-click type integration for the cameras. If I have to do some coding, that's fine, but I'm certainly interested to know if there are options in this space that may have more pre-built things.
Hoping to be pointed in the best direction in terms of what to do with my security panel scenario and what automation platform to buy into. We can assume a "no cost sensitivity" scenario for now. I don't have unlimited budget, but I'd prefer to spend extra money to do it right and get the most flexibility over the long haul.
- Trigger on/off of lights based on if it's dark outside or not (sunrise/sunset as trigger?)
- Trigger on/off of lights based on if it's dark outside on zone violation and arm state of security panel
- Trigger on/off of lights based on motion detection trigger from security cameras
- Trigger security camera presets based on zone violation and arm state of security panel
- Grab screenshot from security cameras based on zone violation and arm state of security panel
- Remote control of lights home (both at and away from home, physical remotes needed in some instances)
- Remote control of security system (both at and away from home)
- Remote control of thermostat (both at and away from home)
- Remote control of garage door (Genie Xcellerator Screw-drive, wired into relay on security panel for remote triggering) - Planning to buy a new opener entirely in general, but nothing picked out yet
- Set thermostat based on security panel arm state
- Schedule based events
- Potential future integration into pool automation system (define pump/salt water generator schedule, remotely control valves) - Current controller is InterMatic MultiWave but open to changing this at some point, very low on my list.
