Father_Barry
OK So I've got my Hobby Boards modules, thanks Eric.
Now I want to integratewith Weather Display. I've identified the ROM IDs after some hassle getting one wire viewer to work. Now I want to check the sensors are working (already found the battery wire not soldered on the lightning detector and a suspect joint on the solar sensor)
So what I am looking for is a list of boards and the type of chip one wire viewer will find and what sensor readings I can expect if they work in spec. Are you supposed to format memory in the rain counter for example, what happens if you do. All this sort of info should be around.
Why isn't this information readily available, surely I'm not the first to want to use these things.
Overall, quite frustrated. I know Tim's book is available, but I don't want to build my own weather station boards, I just paid $500 for Eric to do that
I know this is supposed to be fun, I've been "doing electronics" for over fourty years so I can get there eventually, but I want to get a weather station up and running and need the info quickly.
Is the wind instrument AAG Version 3 or what, and how to configure the barometer in Weather Display.
Any help will be appreciated.
Barry G4HDU
www.keal.me.uk
Barry G4HDU
www.keal.me.uk
