to recap:
Unit 1:
pulled out, tried to install windows 7...yeah, not enough systemto run that...
So, then I tried to install XP, bad disc...whoops...
couldn't find my other disc...so I installed Win2k.
I was surprised, really FAST, installed all drivers by default (Except Elo)
I installed the Elo driver from the 3meg zip. Played around, Touchscreen would not respond. The drivers FOUND the screen, but couldn't see my touching it
ok, to continue my updates:
Unit 2:
pulled out, installed Win2k (where the hell is my original XP disc?)
(have a site license...so not too worried about installing too many of these)
Just as fast and responsive as Unit 1. Surprise, this unit has 20GB hard drive, where Unit 1 had 10GB. Both appear to have the same amount of ram, same processor / mobo. This unit has generic ram. Unit 1 had Kingston ValueRam
Looks like this one is going to go in the Kitchen for some MP3 stuff...
Installed ELO driver, this time from the 30meg zip. EVERYTHING works! WHOO HOO!
TIP:
I don't know if it was this driver, or the options, but Nick mentioned to me that when he tested the touchscreens, he installed the USB and SERIAL drivers. I did so this time. So, I changed two things, I don't know which made it work...but oh well...
The two drivers are DEFINANTLY different. The install had a two different screens between the two programs.
So, tonight, I'm going to try to take unit 1 back apart, so I can re-hook in the DVD drive and wipe, then re-install Win2k, then use the Elo driver from the 30meg file.
So far:
I've been very happy with the build quality, the units "feel" tough (metal case, frame, etc.). The only thing that's "kind" of cheap is the bezel/frame around the screen. It's plastic. I like how they have two power switches. One is power to the PS, one is the "soft" power button.
I have it rigged so as soon as power is applied to the unit it boots. I also need to change the ram check in the beginning. I want it to boot fast, not slow!
I have Win2k setup with Hibernate on, and the unit will get turned off by hibernating (to increase the boot speed).
I also LOVE the ELO screen. NICE, glass, etc. You don't feel like you are going to break it! I like it so much so, that I'm considering changing my HTPC touchscreen to an ELO...but that's for another day!
So far, my initial power readings are:
Booting: 68-70W
Idle with screen on: 49-50W
They are going to replace Audreys...which sit at about 13-20W
I have not turned off the screen yet (I disconnected the keyboard, buttoned it up, then hibernated the PC. THEN after turning it on, realized that I did not disable the "user must enter a password after suspend"...yeah, hard to enter a password when there's no KEYBOARD attached!).
Other thoughts:
the power supply in the base is a bit noisy...I am thinking of replacing the power supply with one of these:
PICOPSU
There are two cooling fans in the head of the unit. One is for the CPU, the other is for venting the head. After I make the PS quiet, if these are loud, I'm considering replacing the head's fan with a different fan. The one on the CPU is a coolermaster...which IMHO tend to be quiet anyhow.
More to come!
--edited added some corrections to sentences that were two 1/2 sentences put together...also, install order for first Unit...
