AutomatedOutlet
could someone please give me their opinion about RadioRA from Lutron, this seems to be the cheapest option for me, at my local home depot, I can pick up two switches for 60 dollars where is lot cheaper then paying 50 dollars for each upb at automatedoutlet.
Those are Lutron Maestro switches, not RadioRA. Those are not automated. RadioRA switches are much more expensive than UPB switches.
You are right in that it looks like we don't have the PCS ones on the website although they are in stock. We will fix that. Although the PCS ones use the same case that Simply Automated uses, they move the IR receiver to the front of the case where you can hit it easier than if it were just left on the keypad.Probably because you can do the same thing a bit nicer at AO. Just buy the keypad and an SAI tabletop enclosure and you're set. The SAI tabletop enclosure is nicer than the PCS one imho.
Thanks for letting me know. We'll get them up there!
