Hermanus
I am hoping one of the Elk gurus can help me out here. I want to set my house in an Arrive Mode as soon as someone opens the main gate. On the gate motor's PCB there is a LED connector that can be used to display the status (open or close) of the gate. What this gives is a 0 VDC when the gate is close and 4.5 VDC when the gate is open (to turn on LED). I was hoping to wire the LED connector to an Analog Zone (34) input on Elk M1G and write a rule to check every second or so what the value of the Analog input is and based on that put the house in Arrive Mode as soon as it goes above 3 VDC for example. When I test the value before inserting it in Zone 10 (the Analog Zone) it measures 4.3 VDC when gate is open and 0.1 VDC when gate is close. Which is correct, as soon as I connect the wires to Zone 10 (Analog Zone) the volts goes up to 9.6 VDC and stays there when gate is open or close, which can’t be used. - Thanks in advance.
