B BTCAD Active Member Apr 16, 2014 #17 Okay thank you, I found a fix. Just to check the memory box. Everything is now perfect, solved!
CAI_Support Senior Member Apr 17, 2014 #18 Good to hear you fixed it. Which memory box did you check?
B BTCAD Active Member Apr 17, 2014 #19 I do not use http://user[email protected] ......... because I think I have to setup my IE and bypass securtity. I just check the ''remember me" box in the pop up window and now Blue Iris can turn the o1 to 1 !!!
