I am installing security cams, and was thinking about how nice this would be.
Run several loops of alarm wire, cat-6, and/or romex around the house just above the soffit. Bring each end back to the same location so it's a giant loop. For installing future lighting, cameras, or other HA/security equipment, just cut a hole in the soffit, locate one of the unused runs with a toner and snip it in half, and terminate each end. The unused half can also be used at a later point for connecting devices on the other side of the house.
Just something to keep in mind the next time anyone builds a house or has the soffits removed for some reason. Just a couple hundred bucks of wire, and you'd never have to worry about pulling wire up into soffits again. Anywhere you wanted to put a device would already have network and power wire available in that location.
If anyone has a good idea on how to do this without tearing everything apart, I'm all ears. I'm waiting for a hail storm to take out my roof so I can upgrade to a steel one. I could set the depth on my circular saw to just cut through the sheathing and then cut a 3-4" wide channel above the soffit all the way around. But until that happens, there's no way to do it without taking down the soffit.
