Hi, will the Axis video servers 241Q work with this haiku application?
I have 12 cameras connected to three 241q servers
If this does work can someone tell me the proper settings?
HI Thanks for this info. This works good while I am in the home and using the local IP address. I did not have to use a port number after the IP address.
However, is there a way to use my Public IP address to view the cameras from the internet?
Sure, you will need to port forward the appropriate ports on your router and if your IP is dynamic (changes), you will also need to sign up with Dynamic DNS service (usually free).
