ddennerline
I have been looking through all the pictures and posts of ELK setups, and there are some clean installations. I wish the Elk black package was “plug-n-play†compatible with Leviton SMB. I have thought of several ways to install the Elk, but there is no clear choice.
1) Buy Leviton 12" Universal Security Brackets (PN#47612-1SB). Option is rather expensive at $50. Plus the box is only 9.5†long, so the bracket will extend 1-2†past end of box – possibly wasting space.
2) Install metal screws into SMB that match the predrilled raindrop holes in back of alarm box. You probably would need to build/use some sort of template as reference. The original Elk 14†box came with two bolts that contained threads on 50% of shank. The Elk SMB had two perfectly placed holes that bolt screwed into. On the backside of M1G there are two teardrop holes. You could probably use the same technique – except use metal screws. The problem here is that you will have to be careful to make sure everything lines up. Also, moving the Elk around after the fact could be near impossible
3) Use Velcro strips around the edge. I have been using this technique in combination Multipurpose Adapter Plate (ELK-SWP) to mount router and DSL model successfully. The benefit here is that Elk can be moved around by simply uplifting the bottom half of Velcro (albeit with lots of elbow grease). The con is I don’t know if the I want a $500 device secured using $4 tape. I think it will hold, but long-term I am not sure.
4) Screw the whole box into the SMB. If the M1G front covert is removed, then 4 screw holes are exposed. The problem here is once the device is screwed in – trying to relocate it is rather difficult. The point (in my opinon) of the SMB is malleable of devices installed within enclosure (to some extent). I understand that moving things around after the fact is probably difficult job too. I just hate concreting devices into box and creating addition holes.
5) I did see someone mentioned using magnetic strips Custom-magnetsDOTcom. This seem s to be most compatible with intention of SMB, but again will it hold up long term.
Ideally, ELK would sell an enclosure/kit that allowed alarm panel to be seamlessly integrated in Leviton SMB. I mention Leviton because for better or worse this is what is sold at big box home store.
