wuench
I suggest conventional wiring of your lighting, with a neutral in every box. You're looking for trouble home-running without a lighting control system in place.
I agree, it's fun to think about doing something non-standard, but unless you are going to pick a system now and go with it, you are better off just following today's standards. A few things come to mind to watch out for that are legal code-wise but not a good idea for automated lighting. 1.) NO SHARED NEUTRALS. 2.) Neutral to every box (meaning power runs to switch then to light, no tailing switches off of the light). This is a big one, make sure the electrician understands this and follows it. You're gonna have to watch them close. 3.) Whole house surge protector. 4.) Good single ground for all electrical, phone, data, TV,etc. Do not ground to separate locations, if possible make sure the ground has plenty of earth around it, not concrete, or use multiple grounds tied together. A ground is like a bucket it will fill up if a surge hits close, if you have multiple buckets electricity will fill one up and take the path of least resistance to the next one. If not tied together directly, this will be through your house and through your equipment. The ideal ground system would be to completely surround your house with ground rods and tie them together, but outside of some commercial installations I doubt this has ever been done.
You might also think about panel locations, etc. Think about things you may want to do in the future and how you would get electric there off of the panel. I really like having a panel in the furnace/utility room for example so if you ever need to change-out/upgrade HVAC you can tap into it. Some houses have two panels, one on each side of the house. This is very nice for future expansion. At the very least maybe consider conduit from your panel to things like the garage, furnace room, attic, near your data distribution panel, etc to facilitate future runs.
